Tool Talk Discussion Forum
Re: 2 stage or single stage ?
Rod (NH)
08-29-2005 16:20:48
Hi Fred,
A two stage is better for the following reasons:
1. Can operate easily to a higher pressure - e.g. 175 psig as compared with 125 or 135 psig. That means more cubic feet of air can be stored in the same sized tank and gives a longer time period between compressor starts for a similar air consumption.
2. Cooler discharge temperatures. A two-stage discharging at 175 psig operates at a lower compression ratio per stage than a single stage operating at 125. For example the first stage discharge would be about 40 psig. The air would then typically be passed through an intercooler device (finned tubing) before being introduced into the second stage where it would be compressed and discharged at 175 psig. The compression ratios per stage would be about the same at 3.6:1. By comparison, the single stage, when discharging at 125 psig, has a compression ratio of about 9.5:1. The higher compression ratio with no opportunity for any interstage cooling results in higher discharge temperatures. This, in turn causes everything to run hotter with less moisture dropout in the storage tank. This is particularly noticeable when a single stage is of marginal capacity for the usage and runs for lengthy periods with little down time for cooling off. Most two-stage units are designed and rated for continuous operation without overheating. I question if most single stage ones are.
3. More efficient regarding power required for the same capacity.
The first two above are the more important considerations for a home shop unit as the power difference is small in the size units generally used in such instances. If you were talking 50 HP (or more) units, the power savings of a two-stage could be a key decision factor. In general, the two-stage would be expected to cost more for a similar capacity.
third party image Rod
fepo
08-30-2005 07:07:09
 Re: 2 stage or single stage ? in reply to Rod (NH), 08-29-2005 16:20:48
Thanks Rod,
wow good info !! I keep that handy :)
that answers my question !
I was thinking more in the lines of 5 HP units (home shop use).
So if I understand correctly, the 2 stage would produce less condensation in the tank as well ?
Rod (NH)
08-30-2005 07:45:33
 Re: 2 stage or single stage ? in reply to fepo, 08-30-2005 07:07:09
The amount of moisture in compressed air doesn't change if it's two stage or one stage. The moisture is in the air at the compressor intake and is a constant amount, depending on the humidity of the ambient air. What changes is that the temperature of the air is lower in the tank for the two stage, the temperature of the tank itself is lower and more moisture condenses out at that point rather than being sent downstream as vapor to condense later on. So the answer to your question is more moisture will be collected in the tank of a two stage, not less - assuming all other things being the same. With a single stage, after a certain run time, the temperature of the tank itself (and everything downstream) gets hotter than it would have with the two stage and the ability to condense out moisture from a higher temperature air becomes less. If you look at only the first few minutes of run time from a cold start, there probably is not that much difference between the single and two stage units as far as quantity of moisture condensed out in the tank. That's why I indicated that single stage units of marginal capacity will have longer run times and more difficulty with moisture control.
