An 80 gal tank will hold more Cubic Feet of air (the CF's are measured uncompressed) at 175 psi than one will at 100 or 125. This additional CF translates into less cycles on the compressor. You regulate the outgoing air to 100 psi for use by air tools and drawing the air down from 175 takes longer than if it were at 125. Cycles are what is hard on electric consumption, and the motor itself. This is where alot of electricity is consumed, in the starting process, and alot of strain and stresses on the motor and the pump. Just like a water well, you want it to start fewer times and run as long as needed. You also have the advantage when the tank pressure is at 175 of not risking dipping below 100 psi when consuming large amounts of air. With a two stage 175 psi compressor the pump will cycle on at about 145 or 150 and pump back up to 175. Even running a blast cabinet or die grinder will probably not cause the air pressure to continue to drop enough to be noticed. With a single stage, 125 psi pump, the pump doesn't come on till 100 or 105, right where you are regulated to. When you are consuming high CFM's and the pump kicks in at 100 psi, then you will experience a dip in pressure before the pump catches up and brings it back up above 100 (if it does at all). If you are going to install a stationary comoressor and have 220V available, you certainly should consider the two stage, you will be better off in the long run. One thing you will discover is more uses for the air. Without a compressor, you are thinking "blow nozzle" and "impact wrench". After you get the compressor, you will be thinking, "blast cabinet, die grinder, air drill, sander, etc" Suddenly you start wishing for more CFM's of output capacity, that you didn't buy. I had a older Sears "4 hp" 20 gal tank, aluminum/steel sleeved oil lubed pump, 220v compressor. It did OK but could not keep up with a die grinder, even the good Dotco one (which consumes less air than the cheap ones) I would have to stop and wait on the compressor, it would get very hot and the electric consumption was noticable. I bought a 80 gal two stage, 7.5 hp, 24 CFM compressor. I never wait on it and it doesn't run alot. The electric consumption is no more and possibly a little less. Charles
