Tool Talk Discussion Forum
With only one chuck . . .
John Garner
08-21-2005 19:52:54
Glenn F --
If you only have 1 lathe chuck, a 4-jaw "independent" (each jaw adjusts individually) chuck would be much better than a 3-jaw scroll (all jaws move simultaneously) chuck because the 4-jaw can be adjusted more precisely and will grip the workpiece more firmly.
Yes, you will need to learn how to adjust a 4-jaw chuck, but once you know how it should only take a minute or two.
The "secret" is simple: adjust opposite jaws in pairs, moving both jaws of a pair the same amount in the same physical direction.
Position the headstock spindle so that the chuck jaws are top/bottom/right/left when looking from the tailstock, slightly loosen the top jaw and adjust the right/left pair before re-tightening the top jaw. Then rotate the spindle a quarter turn, slightly loosen the top jaw (which was a right/left jaw before you rotated the spindle) and adjust the right/left pair before re-tightening the top jaw.
John
