TimV
08-21-2005 07:14:35
Re: Sidney 6' Lathe in reply to Glenn F., 08-21-2005 06:56:30
Glenn: I"ll give this the stock answer: "it depends!" At a bare minimum, you"re going to need a tool holder, a chuck, and some tool bits. Sounds like you"ve got the chuck covered--all things being equal, a 4-jaw chuck is more versatile and accurate, but slower to set up. A 3-jaw is quicker and easier to set up, but slightly less accurate and harder to compensate for wear or toolpiece irregularity. If this is an older lathe, it"s probably got a lantern-post style tool holder-basically an upside-down "U" with a bolt at the top to fasten the tool bit. These will work, but are a bear to set up. A better setup is a Quick-Change Tool Post, or QCTP, but a good one of these (Phase II, Aloris or similar) will run you considerably more than the lathe. China-made ones are availible from Enco and others that will be adequate for what you"re probably going to be doing. In addition to the steady rest, some other handy things to have are a follow rest (clamps to the carriage and follows the workpiece), clamp dogs (used for irregular workpieces in conjunction with a steady rest) a faceplate, a tailstock (I assume it has one but you didn"t mention it) with a live center, dead center, and a drill chuck, plus as many tool bits as you can lay your hands on. Expecting to get all of this is probably asking a bit much, but you don"t know until you ask. It"s entirely possible that the shop owner has several pieces of each of the above, and would be willing to part with a few of them with the lathe.
