Tool Talk Discussion Forum
Interesting!
Matt from CT
05-23-2005 10:49:33
Ok...
For some reason (rectal cranial inversion?) I wasn't thinking of the start-run like a car has.
There's only two wires going to the switch...does the "on" position hold something open by nature of completeting a circuit to ground, whereas the "start" position completes a circuit back to the solenoid?
Just curious...I'll run to Napa one day and buy a new key switch anyway!
Van in AR
05-23-2005 12:17:47
 Re: Interesting! in reply to Matt from CT, 05-23-2005 10:49:33
If you only have two wires going to the switch, its the "run" part of the system and you must have a "starter" button, if so that is what is probably bad.
Van
carb
05-23-2005 13:45:42
 Re: Interesting! in reply to Van in AR, 05-23-2005 12:17:47
I've had a similar problem di-electric grease on the switch contacts after cleaning helped but did not totally get rid of the problem.
