Tool Talk Discussion Forum
About that emery cloth
John Garner
05-12-2005 18:28:33
Carol --
I've never used Bud's emery cloth trick personally, but I've heard of and seen two variants of the same idea. One version a single layer of "emery" cloth (in today's world the abrasive is probably aluminum oxide rather than emery, but the difference is inconsequential for this use). The piece of emery cloth only needs to be a bit bigger than the hole you're trying to drill . . . but too small a piece is hard to handle. The guy who showed me this trick used a two inch square of emery cloth torn from a roll, and let it turn with the drill.
The other variant I've seen is using several layers of plain cloth instead of the emery cloth. One guy I used to work with simply folded a wiping rag into quarters and drilled through it.
John
