Tool Talk Discussion Forum
Good News! You Already Have One.
Roger P.
12-11-2004 12:14:06
If you are using Windows, simply open Paint (Start---Programs---Accessories---Paint),
Click, File -- Open from the menu bar,and browse for your photo (make sure you have All Picture Files selected in the drop down box).
Open the picture file.
Click on Edit in the menu bar.
Click on Select All. You will have a dotted line around your picture.
Now select Image from the menu bar, and click on Stretch/Skew. You can type in the size of the picture (in percent) that you want to reduce it to (i.e. 40% horizontal, 40% vertical). If you don't like the results, just select Edit from the menu bar, and click Undo. Once you have the picture the size you want it, save it with a unique file name, such as JD Carburetor reduced image, or something descriptive. Make sure that you also have the colour depth that you want for the picture selected in the drop down box before you save. You can even save it as a black and white if you like. Reducing colour depth makes the file size smaller, and can be done without sacrificing too much detail if done correctly.
I am sure Apple users and Linux/Unix users have a similar program at their disposal.
Leroy
12-11-2004 15:26:46
 Re: Good News! You Already Have One. in reply to Roger P., 12-11-2004 12:14:06
Where do you have the picture to start with? In a digital camara? Print picture with a scanner? Other?
Roger P.
12-11-2004 16:09:10
 Re: Good News! You Already Have One. in reply to Leroy, 12-11-2004 15:26:46
The photo must be saved to your hard drive, or be taken from a digital camera. If you find a picture on the Internet you would like to use, put your mouse pointer on it, right click, and pick Save Picture As.. Save the picture on your hard drive someplace where you can find it, with a name you can recognize. I save mine in My Documents--My Pictures. Now, when you go to Paint, go to File----Open, then browse to wherever you saved the file, and click on it to open. Remember to have All Picture Files selected in the drop down box for File Types. Most digital cameras will appear like a hard drive in My Computer, so taking files off of it is straightforward. My Agfa CL20 appears like this, is just has to be powered up to download files off it.
Leroy
12-12-2004 06:57:20
 Re: Good News! You Already Have One. in reply to Roger P., 12-11-2004 16:09:10
I have a HP 315, 2.1 MP,2.5x digital zoom (That I have yet to figure out how to use) 8 MB card, 1/8-inch LCD that is about 5-7 yeard old. The book was not very good at explaining if you did not already know what they were talking about and I do not know where the book got to. Should this work like the newer higher priced camaras? I can get the pictures on the hard drive of the Newer computor, windows 98 but after the second hard drive replacement I can't even get on line with it. Works only to print the pictures out or with my scanner or dockuments I make. The older computor that I am using all the time is a windows 95 and the camara will not work with windows 95.
Roger P.
12-12-2004 14:35:43
 Re: Good News! You Already Have One. in reply to Leroy, 12-12-2004 06:57:20
Sounds like you need to setup your internet connection on the newer computer to match the one on the older machine. It wouldn't be hard. Then you could download the camera manual from HP and off you go.
John *.?-!.* cub owner
12-11-2004 13:46:34
Also irfanview.com has a free downloadable program that works good and is easy to use for resizing adjustments, etc.
