Tool Talk Discussion Forum
When I use jack stands I put them
James in North
12-10-2004 11:43:32
under the axle. If I also use wood blocks as backup, where would I put the wood? Under the frame along the side or under the axle next to the jack stand? James
Kevin (FL)
12-12-2004 06:34:17
 Re: When I use jack stands I put them in reply to James in North Carolina, 12-10-2004 11:43:32
Hi James,
Put the blocks wherever they won't interfere with the work you're doing--alongside or somewhere else under the frame. The main issue is to make sure whatever you place under the load, it takes up enough space to allow you to get out from under it. I've seen folks stack tires/rims under a vehicle (with clearance) as safety members. Anything that can support the load and allow you to escape "uncrushed" is good. In other words you don't become the "block" if the stands fail.
