Tool Talk Discussion Forum
More questions about the outdoor furnace
Rod in Smiths F
11-15-2004 17:59:22
Questions:
1. What brand of boiler is it, and what size?
2. How did you orient it in relation to your house to minimize smoke infiltration?
3. What sort of insulation system did you use for your hoses?
4. If I were to pour a pad for a furnace in advance, what would the dimensions be and how high off the ground?
Gus
11-16-2004 02:59:58
 Re: More questions about the outdoor furnace in reply to Rod in Smiths Falls, 11-15-2004 17:59:22
1.I have a Heatmor brand boiler model 200.
It sits approx. half way between the barn and house. (hats both)
2.Winds are usually from the west here so I put it kind of east of the house.
3.I used the 1" PEX pipe run through 4" PVC that has about 2-3" of foam and black plastic all attached as one unit. From dealer.24-30" below ground. Mid Mich.
4.All brands are probably different sizes.Some are on legs, don't need conc. pad. I buried my PVC. first because part of my pad is over the lines.
Check these different furnaces out. And more important the dealer. I am happy with my furnace.Ask for referals.I should have, but didn't.
