Tool Talk Discussion Forum
Ummmmmmmm?
Peanut
10-05-2004 18:15:53
old don,
What does all that mean? Sorry to sound dumb but when it comes to welding - I am. I took some oxy/accet and arc classes when I was in high school (could make one heckuva bead) but things have gone way past my OLD level of knowledge.
I want to weld to repair and some minor fabrication. Maybe I am oversimplifying. I am leaning towards an good quality MIG welder at this point.
old don
10-05-2004 19:07:04
 Re: Ummmmmmmm? in reply to Peanut, 10-05-2004 18:15:53
To put it in easier terms as Kendall stated Mig or shielded metal arc welding (SMAW) would require a gas mixture usually a mix of Carbon Dioxide and 2% Argon to prevent impurities from contaminating your weld so you don't have to chip off slag, this is more designed for more commercial work and requires a gas requlator and tank using a solid wire feed through a nozzle and hose arrangement. This is very prone to outside influences such as wind or a fan close by that's why he stated it should be used inside and I might add the cable length is restrictive.Thus the fluxcore is much better for home use because of no need for gas and is very user friendly.My recommendation is one of these units and a good AC/DC welder because with it and the proper attachments ie; air cooled tig torch w/argon kit you can do all three.Excuse me for being so long winded. It's kind of like asking what time it is and someone telling you how a watch works.
