Tool Talk Discussion Forum
Welder - What to Buy?
Peanut
10-05-2004 07:20:38
I am looking to get an arc welder for light to medium duty welding (fixing things and maybe making a big BBQ pit) around the farm. I just don't know what to look for when looking at used and/or new equipment. I suppose I will weld mostly steel but don't know for sure. Any advice on what to look for? What brands are good or bad quality? What about helmets (auto-darkening any good)? Thank you all.
Mac
10-06-2004 10:10:43
 Re: Welder - What to Buy? in reply to Peanut, 10-05-2004 07:20:38
I've got a mig and ac/dc stick. If I had to get rid of one it'd be the mig. For the farm, it's not as versatile. You can't get the gun in places where you can bend a rod.
old don
10-06-2004 18:37:13
 Re: Welder - What to Buy? in reply to Mac, 10-06-2004 10:10:43
Amen! Mac. 2 cents, old don.
Jerry L /az
10-05-2004 22:27:40
I have a lincoln ranger 8 welder/Gen set That I use love it. Just bought a mig Hobart handler 140 thats just great. 115 volt. for $499.95 not to shaby works as good or better than the miller 135
..... ..... ...Jer
Big Jim
10-05-2004 21:57:10
First, look for a Miller, Hobart, or Lincoln. Doublely so if you get a used unit. A small stick welder will handle anything from about 1/8 inch up. Anything thinner will be tough or impossible. A mid-range MIG will do 20 ga sheet metal and thicker.
When they talk about the capicity of a welder, they always refer to how thick of steel it will weld in one pass. For the occasional weld on a thick section, you can always do multiple passes.
A 130 to 190 amp MIG would comfortable handle any kind of normal farm fabrication and maintenance welding. Once you use a MIG, you"d have a hard time going back to a stick welder for most things. The MIG is easy and convinent. You just grab the gun and weld. No electrodes to change every minute, no flux to chip. I think you will find that you weld a lot more things because it is so easy.
chvet73
10-05-2004 20:17:29
I have a classic Lincoln 'Buzz box'. I paid $75.00 for it used. You can't beat it for the price. Last year we added a 175 amp Hobart mig. I love it. Paid about $600 with cart, an extra roll of wire and a bottle of gas. I think my welding improved with it. They say it can only handle a 1/4". I just finished adding teeth and a new edge to a tractor bucket, they were 3/8" and with two passes it did a great job.
You won't find many deals on used mig, because no one wants to part with them.
Bottom line their both good machines. Depends on what you want to spend and what results you want.
old don
10-05-2004 17:27:59
I gotta tell ya when I first started welding I thought I was hot s#$t then I went to welding school boy was I wrong? I guess for what you're doing an AC/DC welder will work fine but you have to remember you will need about 50amps of supply voltage all the way back wire and all. Then welding rod becomes important because of AC or DC rods then metal types carbon steel vs stainless, and so on then vertical (overhead) very important to use DC. I could go on for hours so maybe you should get one of those small 110volt fluxcore welders that does most garage type welding including exhaust pipe welding. Until you know what CV and CC welders are and 30% and 90% duty, I would restrict myself to starting with something simple and if you enjoy it go from there. PS, if you start welding a lot with a SMAW welder (Shielded Metal Arc Welder) if your lights don't go dim in the house and your wife doesn't complain about the light bill you're good to go.2 cents worth.
Peanut
10-05-2004 18:15:53
 Ummmmmmmm? in reply to old don, 10-05-2004 17:27:59
old don,
What does all that mean? Sorry to sound dumb but when it comes to welding - I am. I took some oxy/accet and arc classes when I was in high school (could make one heckuva bead) but things have gone way past my OLD level of knowledge.
I want to weld to repair and some minor fabrication. Maybe I am oversimplifying. I am leaning towards an good quality MIG welder at this point.
old don
10-05-2004 19:07:04
 Re: Ummmmmmmm? in reply to Peanut, 10-05-2004 18:15:53
To put it in easier terms as Kendall stated Mig or shielded metal arc welding (SMAW) would require a gas mixture usually a mix of Carbon Dioxide and 2% Argon to prevent impurities from contaminating your weld so you don't have to chip off slag, this is more designed for more commercial work and requires a gas requlator and tank using a solid wire feed through a nozzle and hose arrangement. This is very prone to outside influences such as wind or a fan close by that's why he stated it should be used inside and I might add the cable length is restrictive.Thus the fluxcore is much better for home use because of no need for gas and is very user friendly.My recommendation is one of these units and a good AC/DC welder because with it and the proper attachments ie; air cooled tig torch w/argon kit you can do all three.Excuse me for being so long winded. It's kind of like asking what time it is and someone telling you how a watch works.
J.C. IN AZ.
10-05-2004 13:49:19
I have had my 225 Forney for 30 yr's and it still does a good Job,but now the one I reach for most often is my Miller Mig/Tig. It is so nice to use. I wear Glasses so I have the large Lens Forney Helmet and see no reason to spend $100.00 or more for any other kind.A Pro. Welder could justify the Expense. My 2C's worth.
Kendall
10-05-2004 12:51:00
My next welder will be a MIG welder. Probably just the flux core version. Seems like its the wave of the future and arc welders are old stuff. Check 'em out.
Nick from NE
10-05-2004 17:43:03
 Re: Welder - What to Buy? in reply to Kendall, 10-05-2004 12:51:00
The one reccomendation I would make in regards to the arc/wire welder debate. From past experience I have found that the smaller wirewelders work really good for thin stuff and sheet metal. However, I would still use good ol stick for welding anything over 1/8". Also you should consider where most of your welding will be done. If you choose to run gas you will need to run it indoors. Stick and flux-core can be ran either indoors or out.
lucas boy
10-05-2004 10:02:25
the lincoln 225 ac/dc is a good all around welder for heavy metal and thin ,but not sheet metal.ive found the dc good for thin stuff...if you want to do sheet metal you can get a mig welder lincoln or hobart i think are tops .the more the amps rating the heavier stuff you can weld so be honest about what you want to weld when getting a mig welder.... a chheep welding helmet will get you going .my neighbor uses car batteries to weld but ive never tried that..... lucas
old
10-05-2004 08:28:34
Its hard to beat a good old Licoln buzz box I've had one for 20 plus years and it just keeps on keeping on.
TimV
10-05-2004 07:40:46
Peanut: The Lincoln AC225 is probably the "classic" arc welder, and there are thousands of them around. You'll pay around $350 new, and anywhere from $50 on up used (I paid $100 for mine) and they will do nearly anything you want. Going to AC/DC will gain you additional capabilities, such as improved vertical and overhead performance, but of course the welder will cost more. With regard to helmets, I have a cheapie Homier auto-darkening helmet, and it has really helped improve my welding--no more fumbling around and striking the arc everywhere but where you wanted it! If I were doing this on a more than occasional basis, I'd opt for a better helmet--Speedglas, Huntsman, or similar, but I can't justify paying $300 or more for something that gets used a few times a month.
j puleo
10-05-2004 09:32:52
 Re: Welder - What to Buy? in reply to TimV, 10-05-2004 07:40:46
Ive got a 1960's Craftsman 220 arc. It works wonderfull. I cant say how the new stuff is, but if you find an old larger craftsman arc, Its a winner. I paid $75.00. You may want to look into some of the small migs however, I find I use the mig more often than the stick welder in my garage. I use a 20$ cheepie old helmet, works fine, but would recomend a auto darkening.
