Tool Talk Discussion Forum
You work too hard
Gerald J.
08-22-2004 08:43:50
Unless you are flowing a few hundred gallons per minute, the 3/4" hole will handle the hydraulic system flow.
Just screw in a 3/4" street elbow (with Rectorseal #5 on the threads) stop with it to the rear. Screw in a 3/4" close nipple, then a 1 to 3/4 reducing coupling. Then you have your 1" female threads to take your return line. A really well supplied hardware store might even have a street elbow with 3/4" male threads and 1" female threads. Or a reducing elbow and a 3/4 close nipple gets there quickly.
And you've not filled the system with ground up cast iron that will otherwise grind the pump and valve to make more ground steel and iron to further self destruct.
Gerald J.
dfarmann
08-22-2004 14:26:50
 Re: You work too hard in reply to Gerald J., 08-22-2004 08:43:50
Thank You! GeraldJ
My problem is that it will be the Suction side of a 28 GPM pump, and I don't know if I draw that volume threw a 3/4" NPT nipple.
Dave
Gerald J.
08-22-2004 18:07:02
 Re: You work too hard in reply to dfarmann, 08-22-2004 14:26:50
An inch or two of 3/4 pipe won't be much of a restriction at 28 gpm. A lot less restriction than a ten foot hose.
Do you really NEED 28 GPM for your back hoe? the WD45 didn't have that kind of flow but had higher pressure so they cylinders might be a bit small in diameter.
I have a Long 1099 and I find its a whole lot more controllable with a 5 gpm pump than a 10 or 22 gpm pump.
I run it on the JD 4020 hydraulics through a flow restrict or valve to keep from jerking it apart.
Gerald J.
