Hi Jenny,Welcome to the world of wood splitting. Ash is excellent firewood and it splits relatively well. How long are the pieces you will be splitting? Hopefully they are not longer than will fit into your fireplace -- sixteen to twenty inches is usually ideal. What is the diameter of the larger pieces? First off, read an article that my wife and I wrote on the topic. It is posted at>Link You will need a �Wood splitter�s Maul� and a �splitting wedge� or two. Get a six-pound maul with fiberglass or plastic handle. If there is a Harbor Freight Tools store near you they carry or can get an excellent maul (the best available in my opinion) for around $20 and wedges for less than half that. If not, any hardware or home improvement store should carry both at prices in that ballpark. Start with the smaller diameter pieces. Split them in two and then again if necessary. Work your way to the larger diameter pieces. Set aside until last the �crotches� or �Ys� where branches started because they will be more difficult to split. As you split the wood stack it neatly to dry. It should not be stacked directly on the ground if possible but on scrap wood "runners" or anything that will elevate the bottom pieces a couple inches. Don�t be discouraged if you have limited success with splitting at first. You CAN learn to split effectively in a fairly short time. We taught Annie�s mother the fine art and she has become an excellent wood splitter that is impressive to watch. Post back here with any further questions or comments and let us know how you are doing. Dave
