Restoration & Repair Tips Board
The real answer
RickB
05-15-2005 09:30:50
The resistance wire is integrated in the wiring harness and has apparently failed. The reasonable choices are to run a new wire from the ignition switch ign terminal to a new, resisted coil and eliminate the bypass start feature or run a new wire from the switch to a new ballast resistor and retain the coil and bypass starting wire from the start relay. The second would be the cheaper and probably would insure better cold starts.
Weirsdale George
05-15-2005 14:17:49
 Re: The real answer in reply to RickB, 05-15-2005 09:30:50
Thanks for reporting back as to the correct answer. I always wonder if we were close to the answer or not.
You are right to retain the bypass starting feature if you can.
