cam down ?
walt jd b
03-25-2005 18:57:14
what do you mean to turn the cam down??
JPatton
03-25-2005 21:22:07
 Re: cam down ? in reply to walt jd b, 03-25-2005 18:57:14
Walt - The cam is too large in diameter to allow the longer throws on the crank to clear. On A & G tractors it is common to grind flat spots on the cam between the lobes to clear the rods. The problem with the B cam is that it is hollow to allow the oil to flow to the bearings. If you grind or turn too much off of the cam, it will be history. We turned one down with no problem. We used what ever the dimeter is for the bearing on the end. I think it was .750".
Jerry
Drew
03-25-2005 21:39:57
 Re: cam down ? in reply to JPatton, 03-25-2005 21:22:07
I heard a guy once used a 50 cam because it was solid. Then you can flatspot it w/o problems.
JerryBird
03-26-2005 16:26:35
 Re: cam down ? in reply to Drew, 03-25-2005 21:39:57
A "50" cam is hallow ,just like the"B".
