bore size
walt jd b
03-25-2005 18:54:06
i was going to get after market 125 thousant over it will be 4 11/16" ????? ????? ????
a puller
03-25-2005 19:11:21
 Re: bore size/cam in reply to walt jd b, 03-25-2005 18:54:06
your block stock is 4.5"....add .125 to it and you get 4.625....4 5/8 bore. on the cam, you have to either turn it down on a lathe where the rods/crank journals go around, or flat spot it (time consuming but stronger/more durable). its all so the rods will miss, the cam is the hold back on 2 cyl. stroke..lol..we have an A with a 7.25" crank..not ALOT of work..but still ahd to flat spot the cam and grind on teh back plate..and the top
