if 7 will i have clearance?
walt jd b
03-25-2005 05:55:12
thanks for the reply. if i stroke to 7" will i have to grind anyting or will there be clearance for the rods to turn? thanks walt.
JPatton
03-25-2005 06:59:21
 Re: if 7 will i have clearance? in reply to walt jd b, 03-25-2005 05:55:12
Walt - You will have to turn the cam down to clear the rods for sure. Some grinding on the back of the case and top where the access cover is. I haven"t done one yet but have my eye on a "41 if the present owner and I can get together on the price.
walt jd b
03-25-2005 18:57:14
 cam down ? in reply to JPatton, 03-25-2005 06:59:21
what do you mean to turn the cam down??
JPatton
03-25-2005 21:22:07
 Re: cam down ? in reply to walt jd b, 03-25-2005 18:57:14
Walt - The cam is too large in diameter to allow the longer throws on the crank to clear. On A & G tractors it is common to grind flat spots on the cam between the lobes to clear the rods. The problem with the B cam is that it is hollow to allow the oil to flow to the bearings. If you grind or turn too much off of the cam, it will be history. We turned one down with no problem. We used what ever the dimeter is for the bearing on the end. I think it was .750".
Jerry
Drew
03-25-2005 21:39:57
 Re: cam down ? in reply to JPatton, 03-25-2005 21:22:07
I heard a guy once used a 50 cam because it was solid. Then you can flatspot it w/o problems.
JerryBird
03-26-2005 16:26:35
 Re: cam down ? in reply to Drew, 03-25-2005 21:39:57
A "50" cam is hallow ,just like the"B".
