pistons
it has been bor
08-28-2004 18:27:03
it has cat pistons..i believe i have heard out of a D6???.....ask "buickandeere"....or lynn
JDGnut
08-30-2004 08:03:26
 Re: pistons in reply to it has been bored, 08-28-2004 18:27:03
First decide what you are going to do with the tractor... they can easily be bored and installed the .45, 90, .125 over High compression AL pistons... or you can the route others listed.. using the CAT or the aircraft pistons.. but to do this you will have to weld the rods.. not a problem.. but not something you would do on a normal rebuild.. JDGnut
(Also the older blocks had a bigger counter bore at the top.. usually .125 will clean most of this out on an A... or close to it..)
