Oil Drain Plug Paint-Stuck
JKC
05-18-2008 14:22:06
I bought a restored /repainted 1950 MM G tractor with cast iron engine, oil plug in underbelly. It has the square head drain plug. Have tried and tried to get the drain plug unscrewed so I can drain and change the oil. The repainting has apparently stuck that drain plug fast. I am trying NOT to strip or round-off the corners, but need some ideas. Any suggestions would be very much appreciated. Thanks.
larry cook
05-20-2008 00:46:37
 Re: Oil Drain Plug Paint-Stuck in reply to JKC, 05-18-2008 14:22:06
hard to believe the plug would be stuck due to paint. longer wrench with pipe might work. heat is good sometimes.pipewrench usually works, can always replace the plug.
larry cook
GlenIdaho
05-18-2008 15:56:29
JKC;
Try the technique described in the thread below. Although it's for a Ford it will probably work on your Massey.
