Lesser Known Classics Discussion Forum
Re:long fuel pump problem
ray in nc
05-01-2006 18:08:03
SUCCESS!!FINALLY, AFTER A FAILED ATTEMPT TO PULL IT OFF, ISTLL HAD NO FUEL GETTING INTO INJ. LINES.I FOUND THAT IN THE SUPPLY{?} LINE INTO THE REAR OF THE PUMP,THERE ARE VARIOUS SPRINGS AND A LITTLE PISTON.THERE WAS A BURR ON THE END OF THE LITTLE THING STOPPING IT FROM FULL TRAVEL THEREFORE NOT LETTING FUEL INTO THE INJ. LINES .THEN I PULLED IT DOWN THE ROAD AND SHE TOOK OFF. FINALLY. NOW ONE SMALL ISSUE. I TOOK THE FUEL LINKAGE LOOSE ON TOP OF THE PUMP SO NOW WIDE OPEN IT IS ABOUT 1400RPM. I BET I CAN FIX THIS WITH A SIMPLE ADJUSTMENT. THANKS EVERYBODY FOR INPUT,ESPECIALLY JIM. TAKE CARE AND THANKS AGAIN.
Jim in NC
05-03-2006 04:54:34
 Old Time Exhibition in reply to ray in nc, 05-01-2006 18:08:03
Hey Ray and everyone: The Old Time Exhibition will be held in Colfax this weekend. Get off at the Sandy Ridge Rd. exit and go south about 2 miles. A sanctioned OTTPA tractor pull, old tractors, and other "goings on" will be happenin'. Hope to see you there.
