Lesser Known Classics Discussion Forum
Re:long fuel pump problem
S Glick
04-30-2006 18:25:41
When you have made sure that you are getting fuel from the tank filters and lift pump, then you can bleed air off the injection pump with the little bleeders on the injection pump control lid (where the throttle and fuel shutoff is) their are 5/16 headed turn counterclockwise one full turn and pump the lift pump until fuel comes out in a steady stream, close off and do the one close to the block, then when this is completed you can bleed the injector lines at the injector.
