Lesser Known Classics Discussion Forum
engine
f150joe
03-21-2005 15:01:09
I have a BMC MINI 9/16.I am trying to find a manual with spec's, i am trying to overhaul the engine that did not turn over,i was told it was just a headgasket. I did not check it out properly. Im told this is now a leyland. by the way the moter is 948cc diesel i can't get spec's for overhaul,just have manual for part's. Can you maybe let me know if the 1500cc will fit and were can i find one i can use the help. THANKS JOE.
Terry Bower
03-29-2005 19:19:42
 Re: engine(BMC - Nuffield model# 3/45 in reply to f150joe, 03-21-2005 15:01:09
While we're talking about the troubled Leyland
BMC diesel, I have the above Nuffield (1969) which is the cousin to the Leyland (same Brittish co.)that has a cracked block x2 - between the cylinders. I need a block or info
on whether it can be successfully welded.
Any advice would be appreciated. Bower.
