Lesser Known Classics Discussion Forum
oil blowing out of exhaust on leyland
speedbuff
03-05-2005 08:37:01
I recently purchased a leyland 270 that had been sitting for years After quite some convincing i finally got it to run Now it runs but blows oil out of the exhaust ,it actually blows out droplets, and in an hour it will spray out about a quart it seems weak on one cyl what could the caUse of this be ?
Dsl
03-05-2005 15:54:51
 Re: oil blowing out of exhaust on leyland in reply to speedbuff , 03-05-2005 08:37:01
You didn't happen to use ether to start it, did you? The "After quite some convincing" part of your post makes me wonder. If so, you may have broken a ring land or cracked a piston. Or, possibly that was the very reason the tractor has been sitting for some time.
speedbuff
03-05-2005 17:17:44
 Re: oil blowing out of exhaust on leyland in reply to Dsl, 03-05-2005 15:54:51
i am not sure of the history and dare say i used the starting fluid carefully now there were signs of oil all over the tractor so i think thats why it was parked do you think it will be rings or piston actually can you think of anything else that could do that?
f150joe
03-21-2005 15:01:09
 engine in reply to speedbuff, 03-05-2005 17:17:44
I have a BMC MINI 9/16.I am trying to find a manual with spec's, i am trying to overhaul the engine that did not turn over,i was told it was just a headgasket. I did not check it out properly. Im told this is now a leyland. by the way the moter is 948cc diesel i can't get spec's for overhaul,just have manual for part's. Can you maybe let me know if the 1500cc will fit and were can i find one i can use the help. THANKS JOE.
Terry Bower
03-29-2005 19:19:42
 Re: engine(BMC - Nuffield model# 3/45 in reply to f150joe, 03-21-2005 15:01:09
While we're talking about the troubled Leyland
BMC diesel, I have the above Nuffield (1969) which is the cousin to the Leyland (same Brittish co.)that has a cracked block x2 - between the cylinders. I need a block or info
on whether it can be successfully welded.
Any advice would be appreciated. Bower.
Dsl
03-05-2005 18:04:56
 Re: oil blowing out of exhaust on leyland in reply to speedbuff, 03-05-2005 17:17:44
If there are actual droplets of oil exhausting, it won't be valves, as they aren't capable of such a volume of oil loss, so expect worn rings(seems excessive), or, more likely, a failure of the sort I mentioned earlier, sorry.
If you need engine parts for your tractor, I have them; just click on my name to send me an email.
speedbuff
09-05-2005 17:54:50
 Re: oil blowing out of exhaust on leyland in reply to Dsl, 03-05-2005 18:04:56
Just to bring you guys up to speed What I found was a rag ingested by the engine ,caught up in the rings wich were worn to half their diameter to begin with .In short 4 new liners and a set of rings and it runs pretty good, no more oil bath !!!!! !!!
