oops...
Tim of PA
10-02-2007 15:20:54
I used type A transmision oil per one of manuals I first purchased. Have come to find out after a little research ,it has a lower viscosity then recommended for normal. OK, I was thinking if I am redoing hydraulic pump I will make change. well more is in lines than you might think. It is also in all my equiptment. Let me tell you, it foams like crazy when you make the change. Ok J. Schweibert, sorry, I have multiple problems. Please help as you can.
rrlund
10-02-2007 16:21:52
 Re: oops... in reply to Tim of PA, 10-02-2007 15:20:54
That type A trans fluid goes in the hydra power 2 speed,not the hydraulic system.
Tim of PA
10-03-2007 11:24:09
 Re: oops... in reply to rrlund, 10-02-2007 16:21:52
The reason I used type A in Hydraulic Unit is because on page 138, paragraph 394 of the I&T shop manual for the Oliver 1850 it says recommended fluid is SAE 10W Supplement 1 engine oil or Type A Automatic Transmission Fluid. This paragraph is talking about the hydraulic lift system.
J. Schwiebert.
10-07-2007 13:36:34
 Re: oops... in reply to Tim of PA, 10-03-2007 11:24:09
How the answer to the original question: What pressure do you have just driving the tractor using no hydraulics? The PTO has no affect on what you are doing. Yes you should pressure when use move the baler gate, but only what it takes to so the job. Is it a one way cylinder?
J.Schwiebert
10-03-2007 15:43:03
You are correct on the type A fluid. It was in the operators manual for a while. Are your 3 point arms up or down? This 2800 pounds what are you doing with the tractor when you see it on the gauge? Are any of the cylinders you are trying to use single acting cylinders?
Tim of PA
10-05-2007 15:20:23
 Re: oops... in reply to J.Schwiebert, 10-03-2007 15:43:03
I was lifting gate on a round baler. 2800 pounds at top or bottom of lift. I have that fixed now. I did like you said and removed shims. What is strange is I ended up putting them all back in. Now gauge tops at 1900. I noticed plunger was worn where it was seating. I ordered a replacement along with seat and crushwasher and o-ring. It says in manual I can fish seat and washer out with a wire. Correct? I have another question. Should gauge be reading at all when cylinder is lifting. It is showing something over 1000 pounds as cylinder raises. I ran tractor a little with hayrake. So just three point and pto in use. I used your suggestion and checked temperature at 136 F degrees after little use. I ran about 5 gallons of agco hydraulic fluid thru to flush system. I changed filter. It had a good amount of metal in it. I am hoping from pump I replaced. Also I changed breather element. What I removed looked like a stack of laminations.
