Eye nut
Jim Meade
04-06-2007 10:57:45
I looked all over the internet and can't find an eye nut in 9/16" fine. Any tips on where to find one would be appreciated.
J Schwiebert
04-06-2007 19:09:56
 Re: Eye nut in reply to Jim Meade, 04-06-2007 10:57:45
Well I first starting doing this was with the Power Booster program. The guys from Charles City had "home made" so to say lifting eves. Get your self some round or hex bar stock about an inch in diameter and drill and tap it for the head bolt. Then drill a hole cross wise about an inch from the other end and bend say like a 1/2 inch ring and insert throught the drilled hole. Weld each end to the bar stock. That is what they had. The eyebolt I did look up was in a catalof at the local hardware store. J.
J Schwiebert
04-06-2007 19:11:34
 Re: Eye nut in reply to J Schwiebert, 04-06-2007 19:09:56
Forgot to say that 1/2 inch eye was the diameter of the rod. Diameter of the ring was about 4 inches. Sorry about that. J.
