And it runs
Keith-OR
01-29-2006 18:22:38
Rich, fired it up this afternoon.sounds like it is missing on one or two cylinders. Will check it out in the next couple of days. Get some new diesel, fired it up on the old stuff. Wanted to make sure tank wasn't leaking and all fitting were tight before i put good stuff in it.
Keith & Shawn
old
01-29-2006 19:05:29
 Re: And it runs in reply to Keith-OR, 01-29-2006 18:22:38
Keith, when you put the good stuff in or even before you do I would add some diesel fuel supplement to the tank. It might help with the injectors and all. Did you get the e-mail on the hyds????? ????? ?
Keith-OR
01-29-2006 20:24:52
 Re: And it runs in reply to old, 01-29-2006 19:05:29
Rich, I had planned on putting in some fuel supplement. I have some here some place, used it on my Fordson Power Major. Yep got you emails. Haven't been able to do much as my ISP keeps kicking me off.
Keith & Shawn
old
01-29-2006 20:41:46
 Re: And it runs in reply to Keith-OR, 01-29-2006 20:24:52
I'd send you some info on the PTO but the book doesn't have any good pictures of it and how it works. If you have seal problems with the hyds you will need to pull the pto shaft to fix the seal problem. Seems like the seals are a problem on the Oliver hyd systems.
