Oils for Super 77
Keith-OR
01-29-2006 16:48:17
Where do I check the trans,and hydraulic oils on a Super 77. Can't even find where to disengage the PTO either.Thanks
Keith & Shawn
Mike in MI
01-29-2006 18:50:51
 Re: Oils for Super 77 in reply to Keith-OR, 01-29-2006 16:48:17
third party image
Hi Keith, John, & Rich
Keith, here"s a photo of a Super 77 thats shows what your missing on your PTO Assembly. The long-handle on right hand side of the seat.
Hope your seals are ok in your Hydraulic pump?
Had troubles with the photos not uploading give it another try.
Take Care,
Mike
Keith-OR
01-29-2006 20:47:46
 Re: Oils for Super 77 in reply to Mike in MI, 01-29-2006 18:50:51
Hi Mike, good looking tractor. Thanks for the picture so I can see what is missing. Is there a clutch for the PTO or it is the main clutch? Mine seems to run all the time even with the clutch depressed, so I am assuming it is a life PTO. Again thanks
Keith & Shawn
J. Schwiebert
01-29-2006 17:17:10
The tranmisson and final drive oil is check by removing a pipe plug on the righ side of the final drive case behind the axle. The hydraulic unit is checked by removing the breather unit which has the dip stick attached to it. Snaping back on the PTO clutch handle should disengage it. There is also a grease fitting on the PTO clutch throwout bearing. It needs to be greased. How often well it can vary a little on how much you use it. It doe not need to be once a day for most people in this day and age. Questions?
Keith-OR
01-29-2006 18:11:30
 Re: Oils for Super 77 in reply to J. Schwiebert, 01-29-2006 17:17:10
J, thanks for the info. went out and looked for breather, found it check oil. Show nothing on the dip stick. also the PTO runs hydraulic pump for FEL.
There is no lever on PTO to disengage. there is a hole on the lower right side that looks like it extends clear across lower reart of PTO. I guess I will pull off the cover and see what is missing.
thanks again
Keith & Shawn
old
01-29-2006 19:33:53
 Re: Oils for Super 77 in reply to Keith-OR, 01-29-2006 18:11:30
Keith, if you pull that plug to check tranny fluid level and if its to full then you probably have a bad seel in the hyd pump. Not to hard to fix BTDT on my super ** put it off for a year because I was affiard of what I would find. I did it in one after noon. Which is good for an old D.A.V. LOL
old
01-29-2006 17:14:22
Hyd oil is checked at the filler cap in the hyd unit, the cap should have a dip stick. As far as the PTO you should have a lever just behind the seat on the right side, thats your PTO lever. What do I need to do send you a page or 2 from the manual again??? If so drop me an e-mail so I can be lazy and not look for your addy LOL
Keith-OR
01-29-2006 18:22:38
 And it runs in reply to old, 01-29-2006 17:14:22
Rich, fired it up this afternoon.sounds like it is missing on one or two cylinders. Will check it out in the next couple of days. Get some new diesel, fired it up on the old stuff. Wanted to make sure tank wasn't leaking and all fitting were tight before i put good stuff in it.
Keith & Shawn
old
01-29-2006 19:05:29
 Re: And it runs in reply to Keith-OR, 01-29-2006 18:22:38
Keith, when you put the good stuff in or even before you do I would add some diesel fuel supplement to the tank. It might help with the injectors and all. Did you get the e-mail on the hyds????? ????? ?
Keith-OR
01-29-2006 20:24:52
 Re: And it runs in reply to old, 01-29-2006 19:05:29
Rich, I had planned on putting in some fuel supplement. I have some here some place, used it on my Fordson Power Major. Yep got you emails. Haven't been able to do much as my ISP keeps kicking me off.
Keith & Shawn
old
01-29-2006 20:41:46
 Re: And it runs in reply to Keith-OR, 01-29-2006 20:24:52
I'd send you some info on the PTO but the book doesn't have any good pictures of it and how it works. If you have seal problems with the hyds you will need to pull the pto shaft to fix the seal problem. Seems like the seals are a problem on the Oliver hyd systems.
old
01-29-2006 18:05:25
 Re: Oils for Super 77 in reply to old, 01-29-2006 17:14:22
My system adds any body I send an e-mail to and I'm up to around 200 or more so its just plain easier to have you writer me instead of me looking at 200 plus people to find you LOL. Theres times I hate this new Dell computer I have. LOL
old
01-29-2006 18:06:12
Keith-OR
01-29-2006 17:50:15
Rich, see how you are!!! I put yours in my address book....:>) :>)
Keith & Shawn
old
01-29-2006 18:19:20
 Re: Oils for Super 77 in reply to Keith-OR, 01-29-2006 17:50:15
Keith you have e-mail LOL
