better to be LUCKY than good
Bruce in KS
11-24-2005 16:47:42
Well, its not the first time this has happened. I got it working. Took the seat and hyd lid cover off and then started the tractor, lift arms worked! The control lever moved with no resistance after I had the metal grill off of it, because the lever looked purposely bent to slide against the slot in the grill. What I don't understand is why it didnt work before, since I looked under the back of the grill and saw the lever was moving what I thought was the friction disc. Well, I don't think I have a friction disc, or a part is missing, since, when the grill was off, the lever moved with no resistance back and forth to raise and lower the arms. Got a big pair of pliars and lessened the bent control lever so it didn't rub so much against the grill. Put the cover back on, seat and grill, and everything works with the lever having 50% of the resistance it had before when it was bent so much. Oh well, I'm happy, cows are happy as they got a bunch of hay for Thanksgiving.
