3 point arms aren"t working now, were before flud change.Replaced blown hose from pump to pressure valve; arms were working when I turned off tractor after finding the blown hose which was dumping fluid fast. Fixed hose, added 4 + gallons of fluid with the bleed plug (on top of filter) open. Fluid coming out bleed hole had a few air pockets every several seconds for about 2 minutes and I kept adding fluid. Then was steady with no air for 45 seconds and then I plugged it. (Note: I was pouring 40 degree fluid through a small funnel and it was flowing pretty slow, so that is why I gave plenty of time for the air to come out the bleed hole). I had bought a new hyd fluid filter and planned to install it, but couldn"t get the nut to spin on the bottom of the filter and didn"t feel like breaking something else right now, as the cows need hay, so I will do the filter next spring. Anyway, plugged bleed hole, check dipstick, started tractor, worked steering slowly back and forth as it took a few seconds to become smooth, worked remote hoses, both tensed up in their brackets as before, pto works, but lift arms aren"t doing anything. I had to remove the hose from the pressure valve that goes to the "t" that goes under the seat which I beleive runs the arms, but that is back on and nothing is leaking. Anything else I should try? I did not have a gushing flow out of the air bleed hole when I plugged it, just a steady flow 1/3 of the diameter of the hole flow since the oil was cold. Thanks for the help! I appreciate everyone"s insight. Hope I can answer a question instead of asking one someday!
