Did it again
Edchainsaw
09-17-2005 19:10:56
It did it to me AGAIN just as I went to pull the kill button to quit for the night... WHY?
Doug S
09-17-2005 21:36:50
 Re: Did it again in reply to Edchainsaw, 09-17-2005 19:10:56
The temp sender is a grounding switch, so if the wire to the sender shorts, the light wil come on. Check to see if this wire is shorted, or possibly your sender is bad, or feel the hydraulic unit under the seat to see if it is hot. If you cannot hold your hand on the unit, you need pump, or control repair. Normal operating temp is 130 degrees. If the light comes on within 4-5 min from cold, I would say you have a short, or bad sender.
edcahinsaw
09-18-2005 15:23:19
 Re: Did it again in reply to Doug S, 09-17-2005 21:36:50
thanks it gets a bit warm I know running the orbital motor on the grain vac however I am inclined to think its a short because of the timing of the light.
this last time it popped up after I sut the orbital motor off and was letting the engine cool down before shut-down.
