Hydr TEMP LIGHT
edchainsaw
09-14-2005 20:27:24
ok here goes..
when I start up our 1955 the light is off.. 2 min later it comes on.. then when it actually goes to work it has went out
when its on you can shut off the engine and let sit 4 or 5min.. it will be off for a while then back on..
it never done this before.. however we washed the tranny off after a line broke (empting the hydralic oil) the line was fixed. and used but has since sat 3wks.
to me its sounding like a short or messed up sensor...
where is this sensor for sure?
2255tr
09-15-2005 11:46:00
 Re: Hydr TEMP LIGHT in reply to edchainsaw, 09-14-2005 20:27:24
The temperature sensor is located on the left side of the hydraulic housing.It is behind the rear edge of the operator platform near wear the high pressure hose that feeds the three-point and remote levers pass.The switch provides ground to the light.It is a single green wire with a female spade connector atached to it.I can check the temp at which it will ground if need be.
edchainsaw
09-15-2005 21:23:41
 Re: Hydr TEMP LIGHT in reply to 2255tr, 09-15-2005 11:46:00
no light today... burnt out 1/2 tank of fuel on the grainvac--- no light at all.. so guess its "fixed"
thanks for your note :)
Edchainsaw
09-17-2005 19:10:56
 Did it again in reply to edchainsaw, 09-15-2005 21:23:41
It did it to me AGAIN just as I went to pull the kill button to quit for the night... WHY?
Doug S
09-17-2005 21:36:50
 Re: Did it again in reply to Edchainsaw, 09-17-2005 19:10:56
The temp sender is a grounding switch, so if the wire to the sender shorts, the light wil come on. Check to see if this wire is shorted, or possibly your sender is bad, or feel the hydraulic unit under the seat to see if it is hot. If you cannot hold your hand on the unit, you need pump, or control repair. Normal operating temp is 130 degrees. If the light comes on within 4-5 min from cold, I would say you have a short, or bad sender.
edcahinsaw
09-18-2005 15:23:19
 Re: Did it again in reply to Doug S, 09-17-2005 21:36:50
thanks it gets a bit warm I know running the orbital motor on the grain vac however I am inclined to think its a short because of the timing of the light.
this last time it popped up after I sut the orbital motor off and was letting the engine cool down before shut-down.
