Lift Arms ARE NOW WORKING!!!
Bruce in KS
09-06-2005 21:18:32
Decided to check the arms one last time and was amazed they lifted and lowered seemingly out of the blue!
Had no idea how it got fixed, until Larry U. called me to tell me he saw from my picture I had a problem with the linkage to the left/under the lift arm. You can see in the picture that a pin had moved out of the linkage. I saw this right after I had taken the picture and had already tapped and moved the linkage a few times, still didnt get the pin in all the way. The linkage was either bowed the wrong way, or the pin not engaged enough to get the linkage to work correctly. I had no idea how I had fixed the problem until Larry U. called after I got it working! Talk about luck. Anyway, my work isn't done, PTO slips with the mower on it. I didn't get off the hook yet. Figuring out how to check that problem currently!
Thank You Larry U. and J. Schwiebert for the phone calls.
