Early 88
Bill Johnson
06-26-2005 14:48:33
I've recently acquired an old 88 that is a composite of two tractors, a 1950 and an early 1948. In the parts I got with the tractor was a front grill assembly but the radiator cap cover is a little different. It hinges at the top of the "Oliver" grill center bar and has ridges in it. Is it from the early 88? I figured since you had one you'd know. Thanks.
drsludge
06-26-2005 15:17:08
 Re: Early 88 in reply to Bill Johnson, 06-26-2005 14:48:33
Good question to tell you the truth I have not ran the tractor in about 20 years,spent one summer plowing with it with a clutch plow(I-H slat bottom)had carb problem let it sit too long and the motor froze,havent touched it.I cant even tell you if it has a raditor cap assembly,dont recall ever lifting it up.Tractor does need some hood work and the rear panels,dad did just pick up some front panels for it.
Bill Johnson
06-29-2005 19:13:12
 Re: Early 88 in reply to drsludge, 06-26-2005 15:17:08
I finally figured it out. It is the nose piece from an early '48 88 Oliver and someone had somehow mounted a pair of fleetline inserts over top of the openings, thankfully without damaging the nose piece. Since I've got a fleetline hood and side panels, I'll put the fleetline nose and grills on it even though it's a '48 frame.
Bill Johnson
06-26-2005 18:50:19
It's just been an item of curiousity ince I've not seen any other cap covers like it. I appreciate your answer!
