Another picture
Shep Va
05-09-2005 08:50:46
Another picture of the planter in transport.
VADAVE
05-09-2005 17:10:17
 Re: Another picture in reply to Shep Va, 05-09-2005 08:50:46
See what you mean by unloading the front of the MM a little.
Shep Va
05-10-2005 05:06:05
 Re: Another picture in reply to VADAVE, 05-09-2005 17:10:17
Yeah, that planter is really heavy in transport. When going down the highway in transport only the center rib on the front tires gets black, so it really makes the front end light.
May have to get a couple MM weights for the nose :-)
I guess you guys are done planting dave ???
1755
05-10-2005 19:09:26
 Re: Another picture in reply to Shep Va, 05-10-2005 05:06:05
I was wandring if the draw bar on your G1355 is set up like our 1755 it has 2 positions if you make it so it dont stick out as far maby it would help untel you find whaights I had to put ours in to clear the deck of the brush hog
Shep Va
05-11-2005 05:41:05
 Re: Another picture in reply to 1755, 05-10-2005 19:09:26
Yes the drawbar is very simular on the G-1355. I am not really having a problem when hooked to the drawbar, it is when the planter is in transport and all that weight transfers to the three point hitch, that is when the front gets light. It is happening just like you said, because the weight is being transfered to the end of the lift arms and is further back then the drawbar.
Thanks for the thought.
1755
05-16-2005 18:37:49
 Re: Another picture in reply to Shep Va, 05-11-2005 05:41:05
I did not realise the whait was on the 3pt then the only way moving the draw bar would do any thing would be to ty it on the front no good thow have you looked at how the waight Bracket is bolted on I was told that if you wanted to you could put oliver waits on a white but we were at an auction with a 2-155 and a 2-85 I dont know if it works that way on all of them
Larry NE IL
05-09-2005 19:53:06
Hey Shep,
Too bad we're so far apart. I've got a clean White 6100 series 8 rn no-til that would look sweet with the Minnie. Comes with 8 rn rm cultivator. Lost all but my hay ground so I'm retired! Great pictures though. Larry NE IL
Shep Va
05-10-2005 05:12:17
 Re: Another picture in reply to Larry NE IL, 05-09-2005 19:53:06
Where were you 6 months ago when I bought this one???? I looked for a white, or a kinse, but found this CIH on a good deal and so far I am pleased. This planter came from Ohio, so you are really not that far from me....
Thanks
Jake in NY
05-10-2005 06:49:34
 Re: Another picture in reply to Shep Va, 05-10-2005 05:12:17
I just saw a planter just like yours except it was a 12 row sell over the weekend. I think it brought about $2500. There was also a White 2255 and 2-105 that went real cheap. $5000 would have bought both of the tractors with money left over... real rough looking equipment.
Jake
