354 flutter
MPH
11-26-2004 19:21:07
hi
i have an 1850 with the 354 perkins also. and it has the same flutter you talk about. i've done some research on this and the problem and the problem lies in the fuel pump drive. their is a worm gear that is driven off the front timming gears. this is the same shaft that's sticking out of the back of the casting for the fuel pump that you see rotating. anyway the part that is bad is the gear at the base of the fuel pump that is driven by the worm gear. the worm gear is steal and the driven gear is brass and after 30+ years a little wear occurs.
J. Schwiebert
11-27-2004 07:24:03
 Re: 354 flutter in reply to MPH, 11-26-2004 19:21:07
Depending on if it has the heavier drive that little shaft will twist. I have had a few where flow timing the pump will take care of the flutter.
