I don't think a V engine will fit low enough into
ScooterBuck
11-09-2004 19:33:48
Even if you did find a way to match the two with a bellhousing I don't think it would fit in the frame. JMO
Andrew
11-10-2004 18:09:15
 Re: I don't think a V engine will fit low enough i in reply to ScooterBuck, 11-09-2004 19:33:48
you could grind some of the tub frame out but then you run the risk of braking you might beable to get away with a 1800 tub frame.
