Grabby left brake symptoms
Doug Engel
09-22-2004 18:47:06
Brakes seem to work fine in reverse, except for the grabbing. Traveling forward the left brake grabs to the extent that it is nearly impossible to apply it without skidding the tire, about half the time it locks up the tire and slight reverse motion is needed to unlock it (the backlash of the skid has always done it so far). The hour meter only shows 1037 hours and I have spoken with the original (one and only) owner and he verifies the hours, nearly all haying, so it does sound more like a mechanical failure than worn out linings. The pedals return fine and evenly. Is this a fluid filled system and is there anything in there that is going to fly out (springs?) when I remove the cover? Doug
jakej
09-22-2004 19:08:02
 Re: Grabby left brake symptoms in reply to Doug Engel, 09-22-2004 18:47:06
There are no springs, The action is strictly a camming action to brake. The covers on both sides can be removed to expose the innards. The only tricky part is replacing the 3 bolts that hold the disc assy. Checking under the covers is probably the next step, the system is simple once exposed. If you don't have a manual I can send a scan.
