Delco 10DN
Bob
01-21-2008 11:50:02
If your alternator looks EXACTLY like THIS:
Third Party Image
before rushing off to get a replacment alternator, pull the plug out of the back, and connect a jumper wire from the terminal marked "F" to the the large insulated output stud on the back of the alternator, and start the engine.
This "full-fields" the alternator, making it charge at it's maximum capacity. Hopefully, you have a voltmeter, and can watch the battery voltage. It should QUICKLY come up to 17 Volts, and keep rising. (Don't let it run very long "full-fielded".)
Voltage quickly comes up = Alternator GOOD, probably a bad regulator or wiring is causing your problem.
Voltage DOESN'T come up with alternator "full-fielded = Bad alternator.
