Axle pivot bushing
Jack(TN)
11-24-1999 07:09:16
I have a 9n and the axle is sitting real close to the lower radiator neck.The axle looks like it has been slid forward on it's pivot and you can see half the bushing.Can you just slide it back or is it going to have to come apart.Like it is it will tear up the radiator if I drive it much.Looking for suggestions,thanks,Jack.
joe M --- Va.
11-24-1999 12:13:01
 Re: Axle pivot bushing in reply to Jack(TN), 11-24-1999 07:09:16
Sooner or later the bushing and useally the pin wear out narrowing the distance to the radiator.
The cost of a new bushing and pin is much less than a radiator. After swearing for a few hours and a busted knuckel or two you may or may not
get the old pin out. I found that the larger slide hammers used to pull automotive axles is the ticket. Remove the nut and axle adapter from the puller. (If you have a front bumper you will probably have to remove it..) Feed the puller shaft thru the crank opening of the pin and carefully add a washer or two from the back of the pin and then the nut you removed from the puller. Thread it up as far as you can on the shaft and go to hammering. Depending on how frozen up things are it may take a few minutes to pull it out. A snap going back in.. - If the new bushing does not have a lube hole in it like the old one, put one in it and align it up with the hole in the top of the axle when installing it.
lots of luck..
Dave (PA)
11-24-1999 07:25:38
Take it apart and figure out what is amiss. I broke the radiator outlet right off because of a sloppy axle pivot. Are you sure it's the bushing you see and not one of the spacers? The IT manual doesn't illustrate the spacers at all, but you should have one on each side of the axle. The link below will take you to a recent discussion on the spacers.
If the bushing slid forward, I'm guessing it need replacing - it's a tight fit.
