Order Ford 9N Parts Online
Re: 9N dist. timing
Hec In Omaha
12-09-2006 18:57:16
The front mount rotor shaft engages the engine one way. It can't be 180 degrees out unless you really force it. The timing is set on the bench using a straight edge and a ruler.
Good luck
Hec
G.A.TURNER
12-17-2006 20:55:54
 Re: 9N dist. timing in reply to Hec In Omaha, 12-09-2006 18:57:16
so i got the part about distributor to tractor ,so whats the timing process something about a straight edge i remember seeing this process some where but could'nt find it HELP
Bob
12-17-2006 21:06:02
 Re: 9N dist. timing in reply to G.A.TURNER, 12-17-2006 20:55:54
An explanation is at the link below:
G.A.Turner
12-18-2006 16:47:34
 Re: 9N dist. timing in reply to Bob, 12-17-2006 21:06:02
Thanks for the info i hope that i can get it started had to replaced the points distributor cap rotor button plugs .let you know if i get it started Tuesday
