It is finally making sense to me...
Justin D
06-29-2005 15:26:44
Thanks guys - this is finally making sense to me. It sounds like the pin (dowel rod) does have to come out after all. Is this a replaceable dowel rod or is it typically easier to make your own? I am going to take your advice and drill it partially out and try to tap it the rest of the way out. After I get that out then it sounds like everything should pull right as out as explained and I can replace the input shaft seal. Are there any other problems that I may encounter with the Sherman as I take this apart or put it back together?
Thanks,
Justin
Dell (WA)
06-29-2005 16:44:42
 Re: It is finally making sense to me... in reply to Justin D, 06-29-2005 15:26:44
Justin..... ...you should know that the "Sherman" aux tranny is automatically OVERFILLED by the main trannys "oil-slinger" thru the open cage of the tranny input bearing. This constant "overfill" circulates tranny oil in yer Sherman and you NEVER haffta worry about filling or changing the oil in yer Sherman. Simple, eh?..... ...Dell
justin d
06-29-2005 18:01:13
 Re: It is finally making sense to me... in reply to Dell (WA), 06-29-2005 16:44:42
The ingenious and yet simple concepts that make up the many parts of this tractor still amaze me.
