Minneapolis Moline Tractors Discussion Forum
Will overhead valve pistons fit in a ZA?
Zack Peterson
10-09-2006 15:06:12
I'd like to build a ZA for pulling and I'm wondering about using pistons from a 220 overhead valve motor that I've got. The ZA engine will need to be bored anyway. The 220 motor was running before I removed it from an offbrand tractor. I'm thinking about taking it apart and using the 3.75" pistons for my ZA project. Does anybody know if this will work for sure? Is the pin offset the same? Thanks, Zack.
T.R.K.
10-10-2006 18:16:08
 Re: Will overhead valve pistons fit in a ZA? in reply to Zack Peterson, 10-09-2006 15:06:12
"Offbrand tractor?" well you can make about anything fit in anything if you either have your own machine shop of loads of cash.
If its a MM 220 engine, I am thinking that the 220 MM pistons I have seen have a shorter compression distance than the ZA. So if you put them on the ZA rods they won't come up to the top of the bores and you won't have near as much compression. You may be able to use the 220 rods, They should be longer to compensate for the shorter compression distance of the piston. I know they will fit on the crank, but I don't know if you will have any other problems.
I am thinking that someone said Welters sold 3-3/4 pistons (Or was it 3-3/4+.060?) that would work on the ZA rods.
Zack Peterson
10-11-2006 09:24:52
 Re: Will overhead valve pistons fit in a ZA? in reply to T.R.K., 10-10-2006 18:16:08
Thanks for the info. I guess I should have clarified. Yes, it is an MM 220 engine that was shoe horned into a Massey 44. I think I read somewhere that the connecting rods are the same in the overhead valve 206 and 220 as they are in a ZA/ZB. You are correct though, if the pistons are a shorter compression distance, that would create a problem. I might contact Welters about their pistons.
Augie
10-12-2006 18:29:36
 Re: Will overhead valve pistons fit in a ZA? in reply to Zack Peterson, 10-11-2006 09:24:52
If your rules would allow you to run the overhead valve engine 220 that would be the way to go.
Jake Winn
10-13-2006 10:25:56
 Re: Will overhead valve pistons fit in a ZA? in reply to Augie, 10-12-2006 18:29:36
What does it take to put the overhead valve engine in a tractor? was this a dealer conversion that was available?
Augie
10-16-2006 19:19:50
 Re: Will overhead valve pistons fit in a ZA? in reply to Jake Winn, 10-13-2006 10:25:56
Discussion here:
Augie
10-10-2006 18:38:16
Yep, Welters. 3.75"+.060". Made by Jahns.
Jack Wonn
10-12-2006 10:14:27
 Re: Will overhead valve pistons fit in a ZA? in reply to Augie, 10-10-2006 18:38:16
Sounds like a big cluster to me. Might be better off to just pull a Garden tractor or John Deere H. Why dont you just give the tractor to me and let me haul it to scrap.
Tim Teperson
10-13-2006 17:19:40
 Re: Will overhead valve pistons fit in a ZA? in reply to Jack Wonn, 10-12-2006 10:14:27
Jack,
Haul it over to my place. I think I've got a D-206 that will fit right in.
