Minneapolis Moline Tractors Discussion Forum
220 motor
ILMolinepullers
10-15-2006 16:57:41
Does anyone know if a 220 motor out of a 302 will fit in a ZB. we were told that they were put in some from the factory.
ILL John
10-16-2006 17:33:19
 Re: 220 motor in reply to ILMolinepullers, 10-15-2006 16:57:41
Seems to me you're talking about a "flathead" 220. That would be a 206 with a 3 3/4" bore. The ones in the military I believe had hydraulic lifters, don't have one, but if I'm wrong, someone will correct me. I have a 220 in a '37 JTU which came to me with the 186 motor, it'll pull 3x14" anywhere if I can pile enough weight on it. John
MM Guy
10-16-2006 07:02:11
The 220 motor came long after Z production ended. Installing one into a Z takes a little creativity on to plumb up the radiator but it can be done. Not certain if there are any issues with the flywheel and clutch.
LW
10-15-2006 20:15:03
YEs it will fit probably were dealer installed
T.R.K.
10-16-2006 07:00:38
 Re: 220 motor in reply to LW, 10-15-2006 20:15:03
I've Been collecting MMs for 16 years and never heard 302s (or overhead valve 206s for that matter) were "dealer installed" in ZBx. This would require special lower radiator tank and special hood. The only one I have seen with a late style engine had plug in original lower tank outlet and partition welded in opposite side so outlet could mount there.
Better have your facts straight if you "pull" it or someone will nail your hide to the wall. . .
LW
10-16-2006 20:22:36
 Re: 220 motor in reply to T.R.K., 10-16-2006 07:00:38
Well what I was trying to say is the simple fact that the factory did not do it! If it happened in MM facility it was a dealer repowering one, and I am not stating it was a option or any part of it, but if someone had one early on that way that some dealers did repower jobs small bell 800's in vista's etc..... get my point!
ILMolinepullers
10-16-2006 11:21:34
Thanks....You answered our question. Does anyone know about the 220 in the ZM.
T.R.K.
10-16-2006 18:41:48
 Re: 220 motor in reply to ILMolinepullers, 10-16-2006 11:21:34
I'm thinking the military 220 (or was it 226?) engine used in the Z(A) military tractors was basically the same engine as your ZB, except 3-3/4 bore. I am pretty sure Welters 417-498-6496, or Everett 740-922-3335 (If he answers the phone) can help you come up with overbore pistons to make your ZB 206 into a 220 or bigger-like 3-3/4+.060.
