Minneapolis Moline Tractors Discussion Forum
KEROSINE FLUSH
MM STEVE
04-20-2005 19:30:41
JDC IF YOUR SEALS ARE NOT LEAKING AND EVERYTHING IS PRETTY MUCH OK THEN I WOULD WARM HER UP GOOD AND DRAIN FOR A COUPLE OF DAYS AND PASS ON THE KEROSINE. THEY MAKE AN 80W140 THAT WILL WORK JUST FINE.
I WOULD USE KEROSINE AS A LAST RESORT FOR A GOOEY NASTY MESS AND ONLY THEN A 50/50 MIX OF 90 WEIGHT AND KEROSINE.
JDC
04-22-2005 19:38:37
 Re: KEROSINE FLUSH in reply to MM STEVE, 04-20-2005 19:30:41
MM STEVE,I think your right. When I fix the packing again, I will warm it up and let it drain real good and pass on the flush out. I will use the 80 w 140. I have some other leaks to fix, then I'd like to clean her up and paint her.Good old tractor,hard to beat the old molines!
