Minneapolis Moline Tractors Discussion Forum
pto packing problems
JDC
04-17-2005 18:28:12
Hello , I am having problems with the pto packing in my 54 utu.I replaced it last year, it is already leaking. I tryed to tighten it, but it will not stop leaking. I didn"t think that I locked it down to tight when I installed it, but I might have. I wrapped it in the direction of rotation, guess I"ll order another from agco. What is the proper way to install one? thanks JDC
JDC
04-19-2005 19:08:39
 Re: pto packing problems in reply to JDC, 04-17-2005 18:28:12
Thanks for the ideas guys, I was thinking that there was probably something else that I could use. I will try to find some packing on my own, instead of ordering through agco. I also might go ahead and change transmission oil. What do you think of flushing with kerosene,will it hurt older seals? I guess it shouldn't. Also is straight 140 still available, I don't see it around anymore.Guess I'll use multi weight if not
MM STEVE
04-20-2005 19:30:41
 KEROSINE FLUSH in reply to JDC, 04-19-2005 19:08:39
JDC IF YOUR SEALS ARE NOT LEAKING AND EVERYTHING IS PRETTY MUCH OK THEN I WOULD WARM HER UP GOOD AND DRAIN FOR A COUPLE OF DAYS AND PASS ON THE KEROSINE. THEY MAKE AN 80W140 THAT WILL WORK JUST FINE.
I WOULD USE KEROSINE AS A LAST RESORT FOR A GOOEY NASTY MESS AND ONLY THEN A 50/50 MIX OF 90 WEIGHT AND KEROSINE.
JDC
04-22-2005 19:38:37
 Re: KEROSINE FLUSH in reply to MM STEVE, 04-20-2005 19:30:41
MM STEVE,I think your right. When I fix the packing again, I will warm it up and let it drain real good and pass on the flush out. I will use the 80 w 140. I have some other leaks to fix, then I'd like to clean her up and paint her.Good old tractor,hard to beat the old molines!
Roger in Ks
04-19-2005 07:26:06
Go to your local Oil Field Supply store. Ask for 12 inches of Teflon coated packing that goes around the pump rod on a well head. Lots cheaper than Agco and will last longer. What I ussually get is 1/2 inch square. It has to be cut down the middle so it will fit. Save what is left and hope you can find it later.
Kelvin
04-18-2005 18:48:38
You might try putting some faucet packing string in there with what you got. Just put a few turns in there behind what's already in there. I put some on Daddy's ZB and it worked O.K. a few years.
What worked even longer-About 20 years ago an old mechanic pulled the inner fibers from a Buick rear main seal-the rope type. Then he stretched the graphite coated outer shell as long as he could. I put that in there and it lasted about 10 years.
