Minneapolis Moline Tractors Discussion Forum
Thanks, how about tire pressure and wt brackets?
Troy
09-02-2004 22:50:06
Thanks for the good advice.
Track will be hard and dry most likely. 10# in the rears right now.
For building suitcase wt brackets, should they be side to side right in front of the rear tires or from the rear tires forward to the front?
Will the 4 holes up front by the hand crank hold a bracket or should I reinforce it around the front to the other front holes on the sides?
Am I thinking too much? Sorry, just trying to build things once, not over and over....The pull is in 8 days so I may have to just use wheel wts this year. Are 2 bolts per wheel enough or do I need 4 to be safer?
Thanks again!
mo4xdadad
09-03-2004 13:22:52
 Re: Thanks, how about tire pressure and wt bracket in reply to Troy, 09-02-2004 22:50:06
We use the original cultivator brackets that mount near the front and come out with square tubing on both sides of the tractor, then down, with a piece of heavy steel( like an old road grader blade cutting edge) welded to this going forward about even with the front wheels as low as possible. Make sure it is high enough to get on the scales though. We have a belly bar, and also a bracket across the back. About 12 to 14# in the rears 14X9X38 field and road firestones. your rear air depends on your specific ply, make, and size of tire, sometimes it even varies between the same manufacturer as to where the tire was actually made. Just play with it and have fun. Check your holes when you end your pull.If your tires look humpy you need more air.
If They look pretty flat then your probably close.
