found leak, Big Dean help
mikestractor
04-05-2006 15:14:01
It is leaking at the line going into the banjo fitting. No other areas are wet. You can actually see some fuel coming from the line at the fitting. How do you fix this.
ErnieDD
04-06-2006 16:00:59
 Re: found leak, Big Dean help in reply to mikestractor, 04-05-2006 15:14:01
There are two copper washers above and below the banjo fitting. You could try a little more tighten on the banjo bolt. If that don't work, replace the washers. If you need a quick fix anneal the washers and reuse.
mikestractor
04-07-2006 09:49:20
 Re: found leak, Big Dean help in reply to ErnieDD, 04-06-2006 16:00:59
is that line under pressure, if you take the washers out to repair? Will you have to bleed out the diesel lines afterward?
thanks
