Spears Removed
Willy-N
11-16-2005 11:50:21
third party image
I made holders for the Spears when removed. Now I won't poke the cows with them when done. I also plan to use this mount for a front snow blade on the MF 135. The blade will pin into the mount like the spears. The spears have pins that lock them in so they won't slip out of the holes. The mount is made of 1/2" thick steel and the place the spears lock into is also 2 plates each of 1/2" thick steel with 1 1/2" holes drilled in them. That way if the spears get bent I can replace them easy later. Very strong set up for lifting now. I made a Bale Stop in case one wanted to go back over the lift arms. I stab them in the middle so the plate is as high as the top of the bale. Mark H.
