No. PTO lever needs to be pulled up.
Jeff-oh
06-14-2005 05:47:43
See the visual posted above.
Up is engine driven PTO. i.e. the PTO turns at a fixed RPM. (540 RPM when the engine is at 1700 RPM)
Down turns the PTO at 1 rotation for every 20 inches of travel. Yes it will reverse the PTO direction when you back up.
Pull your left hand inspection plate (the one with the shifter. Then move the PTO gear by hand and see how it engages, inspect for worn teeth etc. (engine off of course) then look at the gear fork (this is the little arm on the inside of the inspection plate that engages the gear) The angle may need to be adjusted to make full engagement.
I would be a little concerned about holding the lever in place to maintain PTO engagement as this will lead to wear on the fork and the gear race.
Jeff
(thats interesting the service manual clames 540 RPM at 1500 engine RPM and 1 rev per 19 inches of ground speed... guess they even had conflicting info)
Bob N.Y.
06-14-2005 16:35:50
 Re: No. PTO lever needs to be pulled up. in reply to Jeff-oh, 06-14-2005 05:47:43
540 rpm pto on my 1960 65 gas was 1480 engine rpm. My 1964 65 diesel runs at 1700 engine speed for 540 pto.
