Drilled out the doughnut for the hose and solder i
mtnbikerman
05-06-2005 18:47:14
Then the other end started leaking and the leak off line to the tee. UGGGGG HHHHH H
Jack in NB
05-08-2005 05:14:31
 Re: Drilled out the doughnut for the hose and sold in reply to mtnbikerman, 05-06-2005 18:47:14
Uh Huh. Those things happen.
Keep going - you'll get it licked! (- or stopped - licking would taste bad..... It's a rainy Sunday morning - couldn't resist!)
And a safety note re my earlier comment about splicing the lines - I forgot to add the caution - just the low pressure lines should be operated on.
NOT the heavy high pressure lines going from the pump to the injectors!
Good luck, and let us know how you make out.
Jack
